02 viper not running rite
craigjschr
rochester
ok i am haveing a bit of troubal with my 02 viper er. it seems to be running fine but when i give it the gas it seems to be geting speed slowley not like ushual when i hit the gas it just goes it has been takeing its time but it does not do it all the time ethier. i cleaned the carbs beging off seseon just cleaned PV again and set them.
thanks
Well I am just throwing this out. It could be something that clogged the carbs again? It could be your plugs? Check your compression maybe it is down. I did notice using different grade gas does make a difference.
Just things that come to mind. hope this helps
