Occassional Battery Issue
downchild21
nb
Hello,
I have an 02 Viper that has an intermittent battery problem. The battery is new. It works good for a few trips out then,while out travelling ,i'll go to start it and the battery will be dead.The battery will not charge during riding. Manula start and everything is OK. If I take it out and charge it , it will be OK for a couple of weeks and then die while I am out on a trail. I have checked the harness for rub through and it is OK. The only other thing I notice is the hand / thumb warmers are not nearly as warm as the ones on my other viper.
Any suggestions?
Thanks in advance
check your voltage regulator, with motor started put a volt gauge on battery, gauge should read around 12 and go higher when reved
