Clutch setup
Rivaz
Oxford MI
Can anybody tell me or direct me to a good clutch set up for a bender piped viper. I have searched for hours...and hours . Lookin for low and mid vs top speed. Thanks
There is no good 1 clutch set-up....
didn't you just have One Stop put your pipes on ???
what did they do for your clutching ??
What is the sled doing now ??
I really can't help you ...but Turk will be asking the same questions. ;)!
yeah they did and I'm going over there tomorrow so I was looking for any other user setups to compare too. I couldn't get the revs over 8000.
clutching
Somethings going on with that rpm. With the bender kit they give you loaded up 8ek and new primary spring sec spring and helix.I found that with that kit it would over rev 8900-9000.Run the heel clickers loaded as much as you can in the heel 7-8 washers and 4.5-5.5 tip.I think the bender helix is way to aggresive. I'm running a roller rooster 41\37 silver at 70-80. I also run the shockwave sec at 45 straihgt and it works well to! With the above set up pulls 8600-8700 all the time, pulls hard.
