supersrx
Hi guys, can you help my 97 VMax has dim lights all lights. Sled runs fine.
thanks if you can help.
Tough to say from your info.
Could be an old bulb.
Are you running any accessories like a face shield heater or GPS?
Does the headlight dim more when the hand warmers are turned up? When you hit the brakes?
One easy way to free up some juice is to go with a LED tail light
supersrx
Sorry sled runs fine but brake light and head light are vary dim and the hand warmer are barely working
PNPerformance
I,m checking out a 2001 srx tonight that has the exact problem that your sled is having.supersrx said:Sorry sled runs fine but brake light and head light are vary dim and the hand warmer are barely working
supersrx
Hey thanks I will keep an eye open
Is the Vmax hard to start as well. I would ohm out the stator to see if it is still good.
My 97 is on its third stator. First one factory and the next two have been used.
tedgoesfast
do you have any add one accesa like heated shield
PNPerformance
The 2001 srx had a broken wire in stator.Causing dim light'ssupersrx said:Hi guys, can you help my 97 VMax has dim lights all lights. Sled runs fine.
supersrx
the sled runs great and starts fine .I'm going to put on a new voltage regulator tonight.
