Stubs
Hi I'm new to this site and was wondering if anyone can help with how to the sc-10 3 in my 2000 sxr 700?
SX_SLAYER
im not sure if the SC-10 will do a direct mount in but i know ski-doo does have a "SC" model that bolts right in... no modifications...
WELCOME TO TY!!!!!!!! =)
harness racer
i got a srx here with a sc-10 III . it requires plating
Stubs
Ok I thought it did but I wasn't sure thanks for the help
harness racer
its not a big job , i have pics and hole locations if yu want them aswell as plate thickness.
Stubs
Ya that would be great thanks!What do you think about puting the polaris xtra 10 in the same sled?
harness racer
Do You Want Pics I Got One Of Those Too!!!! And It Works Great!!
yamyrider
the xtra-10 is a great inexpensive upgrade from the No-action suspension...harness racers sled hadles great in the trails...transfers...and is easier on the body...did not lose any speed either with the xtra-10.
Stubs
I havent done either yet. I was thinking on the xtra 10 and yes I would like those pics! Again thanks for the imput
Stubs
I decided to go with the xtra 10. I have a guy near my place how will put it in for a couple hundred bucks is it worth the money or when I get the info and pics from harness racer should I just do it my self? Oh need to get it do before Friday nite cause I'm going sleding>
the polaris Edge would be another good option and has been done by many on here. it seems to be a very easy swap. i don't know if the extra10 and extra12 are similar, but jbshocks does not recommend the extra 12 swap. Stubs, this site has a lot of good info and dimensions for some skids.
http://www.jbshocks.com/edgeswap/swap.html
Stubs
Ok thanks alot Ill check it out!
