Well when I tried to cross the rail-road here to get to the trail, I was going slow but my ski got on the rail and now my alignment on that side is a little on the inside, how do I align my ski to fix this, I've check in my manual but they say to contact a yami dealer if the ski alignment is off, I would like to do it myself. Anybody can help me on this or a place where I can see how to do it. Thanks guys, this site is awesome.
sleddineinar
There are some really good write-ups in the tech section about this.
I did a search but couldn't find anything, in the tech, faq tech and SRX/Viper sections, I must be blind damn
check the TECH SECTION..it's there. I printed it out myself.To much to type on here..unless you got a couple of days.
here is something
line UP YOURS by Betheviper
WARNING
Do not use the dam bar
The dam bar doesn’t take into consideration bent skis, spindles, and wore parts. You don’t take the tires off your car to do an alignment do you?
Why and how can anyone line up a sled with loose parts? the front end of your sled is loose new or not. Lets start first with tightening this up first. If you check your spindles you can move them around with the weight off the sled. to cure this remove the spindles and the spindle bushings. stand the bushings up and cut a slit down one side of it about 1/16in. wide. do this to all the bushings top and bottom. Now cut a piece of coffee can into 4 strips 1in. by 2in., I prefer Foldgers but I suppose you could use some generic brand to save money. Don’t use tea bags as they wont work. Now install the lower bushings back in the trailing arms with the coffee can on the the outside of the bushing. Install the spindle in the trailing arm. Depending how wore out you bushings and spindles are will determine if the spindle will fit. if it does not then remove the bushing and shim (coffee can) trim 1/4 in. off the shim and repeat until the spindle slides very tightly up in the bushing. When both the bottoms are done do the same for the tops. When you do the final installation I have found that the most convenient place to put the slit for the bushing is at the outer rear corners so the grease that leaks out can be easily wiped off.
Front end tight now right, NO, check your radius rods. These things have been smacking around since day one. The other problem with them is that they are not greaseable so the collars inside rust . This in turn makes the bushing wear out even faster. Lets fix both problems while we are here. First remove your bushings and collars. clean up any rust on the collars. Cut the same slits in the bushings and do the same shim trick to make the collars fit tight. The other problem is easy to fix, install grease fittings in all the rod ends. This makes for a little more cleaning but a lot tighter front end.
At this point you need to make camber adjustments before you can do the rest of the alignment. Thank you YAMAHA for making it so dam hard to adjust this. Some people use the bar to do this or a angle gage on the trailing arm. This doesn’t take into account the rock you hit on the side of the trail last week. that is why I use a level on the top of the ski . Ski should be setting level when you are done.
As for the rest of the front end check it all out and replace what is loose. A loose part pounding sends vibration through the whole mechanism and will wear other parts prematurely. If you are doing this to an SX or V-MAX you will probably need to buy a SRX or Viper bell crank. The one your sled came with is a bushing and is not very tight. Even the srx/viper bell crank has some play. WHAT BRAND CRANK Check your spindle to ski collars and bushings too. This is another non grease able part that is subject to a lot of water. The only location for a grease fitting for this requires that you drill and tap the hole at an angle. Tricky to do so if you don’t dare then just remove your skis a few times a year and grease them.
Front end tight ??? if so then we are ready to go. First you will need to make a trip to the metal shop. Buy a piece of 2-3in. band iron 9ft. long. and two pieces of band iron 1/2in. by 2in.. The other things you will need are two pull straps, tape measure, four 2x4s 6in. long, and a person that weighs as much as you do with your gear on (within 20lbs or so, unless you are anal retentive then we better get out the gram scale).
Ready to go??? We will assume that your rear skid is adjusted just the way you like it and that your track is centered (that is another story). First place the 2x4s on the floor just in front and behind the track to one side so you can place your long straight edge along side the track on the 2x4s. This will give you a thrust line to measure to. Place the other two under the front of the sled so to support the straight edge . At all times make sure that the straight edge is against the track front and back. Set the small pieces of band iron under each carbide so that the ski balances without touching. This will allow the ski to float around and let you get an accurate reading from you tape. With your fat buddy on the sled have him move around to settle the suspension out. Hold the bars straight , If the bell crank is not in neutral (this occurs when the the lower part of it is pointing straight at the center of the sled) you will need to adjust the center rod. When the bars and bell crank are aligned then strap the end s of your bars tight to the back bumper so it wont move. This will free up your buds beer hand. Keep the beer flowing to your buddy so as to keep him on the seat but not fast enough to cause him to fall off prematurely. As far as the tape measure goes if you don’t know what to do with it then you should not be doing this. Measure to the carbide bolts to get close then finish with the carbides themselves. I usually set mine for 1/8 toe out at the end of the rod. More if you are a lazy rider (makes steering not as responsive)
Something to note while looking at your skis in the riding position. Where is the contact patch on the floor (with alignment pads removed)? If it is front to middle of carbide this will cause the ski to dart or wander even if your front end is tight. The correct way is to have the rear half of the carbide touching. If you need to correct this you will need to shim the back of the ski rubber. There are two ways to do this. One is to add rubber to the existing one, the other is to add a metal shim to the ski and rivot it in.
Well this should get you started on a good line up. Remember that if you change anything, like limiters or shock preloads, then a steering correction could be needed. The reason for this is that as the suspension is compressed on a Yamaha the skis toe out further and further. So when your dealer jacks your sled up and lines it up with the dam rod then be assured that you have just paid for your sled to be aligned for the few times that your are riding with the front end in the air. On the off chance that the dealer does the rod alignment with the weight on the sleds nose, it may be close enough to ride it and not have a problem. YEH THATS WHAT I WANT CLOSE ENOUGH. Do it yourself and make it right.
good luck
WARNING
good luck
I can't believe I typed all that so quick...
Ok, thanks, thats a long read hehe, seems like there's lots to do just to align the ski's. I would've tough that the things would've been easier than that..
snowhite
It's always easier to do than to undo!!! Line up is not that bad, buy a box of beer and have at 'er,patients will get you back on track......I did not feel like doing it this season, asked the dealer and he said $ 42.50. brought it right in and it was done in an afternoon....And the also adjusted the oil cable for that price.......I thought it was a great deal....
Nick
Nick
Not sure if there is more in here: http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/sledTechIndex.html
crewchief47 said:Not sure if there is more in here: http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/sledTechIndex.html
Thats fantastic, thanks very much, I like to see pics
Will check probably tomorrow and probably do it. Thanks guys, lots of knowledge and excellent info on this site.sleddineinar
I rebuilt my front end this fall and used Betheviper's writeup to shim all the bushings. When I did the alignment I found that someone had used perm. loctite on all the threads, not just jam nuts either. What a pain. I suggest you NOT use perm. loctite, and only loctite the jam nuts.
Be sure to check your parts carefully. You may have bent a rod, or twisted the spindle splines a bit. They don't simply move, you likely damaged something even if just slightly.
sleddineinar
I replaced 2 bent trailing arms and 3 bent radius rods, when I rebuilt my front end. I replaced the 4th radius rod, so that the colors would match.
Motorbreath
bluemonster1 said:stand the bushings up and cut a slit down one side of it about 1/16in. wide. do this to all the bushings top and bottom.
I don't quite get this part. What's the purpose of the slit and where should it be cut? A picture would say more than a thousand words since my technical english isn't as good as I wish it was.
you make a slit in the bushing,usually there is one there.I just keep the bushing(plastic ones) tight when I run it thru my bandsaw blase.That makes the gap on the slip a little bigger.Now take some alum. or coffee can thickness metal and cut to width and wrap around bushing,enough to close the slit gap when bushing is pushed back into place.Now the bushing is tight again when any shaft goes thru it.
bear cans can be used at the beginning of the night, coffee cans are for after 2am to keep you awake,
all the mod stuff to make your sled handle and ride a little better are below
learned it all from you betheviper and it works to..lol
Motorbreath
no, the slit goes in the plastic bushing that it goes into, this bushing is left alone other than a good smoothing.
