What are you guys ruuning for 600- 660 feet?
Also I have the aaen roller clutch with a 52-48 helix brown spring its set up how aaen recommended I was wondering though if this setup is the best for a shorter distance?
Thanks any help will be appreciated.
Jason
Jason
What are your rpm,s from start to finish. What is your gearing now? Do you have any clutch tuning experience? Your gonna have to do a lot of tuning yourself to get the sled competitive.if you want help you must give 10X more info then your giving us now.
YAMMIEGOD3:16
I USE 21-40 BUT HAVE NO IDEA WHAT WOULD WORK WITH WHAT YOUR RUNNING. 3:16 (yammie tony)
My rpm's are at 8500 start to finish, my gearing 21-37 it had about 3/4" of play in the chain also, I also have v-force reeds. I am pretty much a noobie at clutching but can figure things out quickly.
Thanks Jason
Thanks Jason
Should I lower my gearing for 660 feet?
