hey guys has anyone ever had oil and gas come out the other end of the powervalve cable by the servo motor? I never have before until one cable had it bubbling out?
and question 2 i read that the oil adjustment cable optimumly should be in between 19-20.5mm but, mine wont "unspin" that far. It goes to about 12-13mm and thats all the thread i've got before it "unspins" off. I have a varyflow aatac and handle bar risers and was wondering if maybe that had something to do with it? Maybe the previous owner changed the oil cable?
staggs65
where are you measuring for the oil adjustment, you should be pulling the upper half of the cable sheathing out of the adjuster and measuring that gap, if that is what ur doing than I don't know?
you got to pull appart the two halves(open the oil pump)then measure the gap.cobysum said:hey guys has anyone ever had oil and gas come out the other end of the powervalve cable by the servo motor? I never have before until one cable had it bubbling out?
replace #20 and it should help the oil leak.
