throttle cable
SRX_Dave
Trying to get my throttle cable loose from the threaded plate over the carbs. I loosend the jam nut but the entire cable is twisting when I try and thread it out of the plate. I just had it off last week and the pivot worked fine. WTF? Any ideas? Dave
MOst likely, the cable (black part) has just enough bend in it to hang up on the adjuster(metal part) Try holding the cable straight and twist away
