I bought a team rapid reaction secondary used for my RX-1, but I'm not sure exactly how it mounts exactly compared to the stocker. With the secondary I got two large dia washers of different ticknesses and one smaller dia washer, plus a different sleeve to go into the secondary (the one the bolt slides through). I guess my question to anyone who has one of these is when you put it on, what exactly did you change and what did you leave the same (as far as washers, sleeves, shims, etc.) If anyone has a copy of the mounting instructions that came with it that would also be fine. Lastly when I put it on will it mount solid to the jackshaft or will it remain floating like the stock secondary? Thanks to anyone that can help!
