Srx 700 running rich pto cyl.148.3 jet
madpat
Laona, Wisconsin
I have a freshly rebuilt Srx 700,reed spacers,v-force reeds(1st gen),heads cut,stock pistons.Sled runs great at idle,1/3 throttle.plugs look brown and dry.when i crack wide open it falls on its face,will not redline(wont go past 7000 rpm.pto cyl.plug is wet,middle good,mag good.I checked the jets thinking someone put in bigger jets.Pto 148.3,middle 146.3,mag.146.3(all are stock).I tried to drop the needle in pto side didn,t help plug still wet.I,m going to try a 147.5 jet tonight.Any ideas i would think by the mods i did it would use more fuel not less?I adjusted the power valves when i put it back together.Any ideas THANKS FOR THE REPLYS MadPat
