Power valve cable pic anyone
craigjschr
rochester
i was wondering if anyone had a pic of the servo with the cables routed i want to make sure i have them in right.
thanks
Top was on the inside (air box side)
Middle on the outside
Bottom in the middle
thanks for the pic. i was wondering if thier is any way to check the servo to make sure it is working rite. i pulled the cover off to see if it was moveing and it does move when i move it by hand and then turn my key it goes back but how do i tell if it is opening all the way when it is sopose to.
thanks
idle down below 900rpm and servo will turn all the way open, I believe it starts to open around 5000rpm.. will open more as rpm increases...
