2003VIPERER
was out riding the other day and all of a sudden down she went. engine shut right down. thought it was a bad plug. changed the plug and same thing, backfiring and sputtering. got her home and pulled the plug and put my finger on the hole and pulled her over. NOTHING!! i thought wtf. so i looked down the hole with a light and the piston looked fine. so i pulled the power valve out, which by the way was stuck , after some nice tugging and some brake clean she came out. looked in the hole and OMG nice big hole in the side of the piston. now the cylinder looks ok. i felt it with my fingers and the bore was still smooth andyou could still see the cross hatching on the bore. even though there was a lot of carbon buildup i was shocked.
my question is , do you think this burnt down because the power valve was either stuck closed or was not adjusted right. i did clean them at the begining of the year, roughly 1100 miles, and i run amsoil interceptor. by what i can tell i would blame it on the power valve being stuck closed. let me know what you think.
