viper gas gauge problems???
sledtwin
Mass
my gas gauge now reads full all the time ? was working fine till 2 weeks ago?
anyone know why? Do I need a new sending unit or is it stuck?
Thanks TY
Viper gas gauge???
I haven't looked in the tank with a flashlight, I can see the middle of the sending unit rod without one, I will use a flashlight to look to see if the float came off or is stuck, thanks.
Can't see much, tank opeing is too small, even with flashlight
the gauges normaly are resistance to ground i would look for a rub through in wireing harness unplug sender if it gos down then its from plug to sender if wires ok could be sender
