Electrical Upgrade???
krazykev
Maple Grove, MN
Can a '98 SRX be updated to the '00 SRX or newer electrical? I want the twin headlight. I bought almost everything I thought I would need but I read a thread that said you have to do some welding on the motor...something about a crank sensor? Any info anyone?
I have the stator, flywheel, coils, wire harness (both), CDI, reg and rect, headlight. All for a 2000 SRX. Thought all I needed was the gauge pod. Is there more to this?
If all I have to do is some grinding then I'll proceed. Grinding is easier than having to weld aluminum. I'll see when I try to fit. Thanks.
