Clutch Alignment-Viper
02ViperMody44
Life Member
Uitca, NY
I've blown two belts this year. Both Ultimax 3 belts. Now going to stick to Yamaha belts. I'm also going to check the alignment of my clutches but my question is when you check the alignment on the secondary, since it floats, do you measure pushing on the secondary towards the motor, or pulling against the belly pan. Just trying to get it right. I've checked the other posts, and it really isn't addressed in whatever I've read as where the secondary is positioned. I'm assuming against the motor.... :EXER:
i set mine to be at float at measurement so it moves 1mm under and 1mm over spec dont know if thats what it says in manual
push aginst the bearing pic,then have your 1-2mm free play towards the outer side of the sled.
or what CB said would work..
