GYT on 96 500xt ?
Yamaharida
Canada
Has anyone out there put a set of pipes GYT twin pipes on a 500 vmax. I bought the set of pipes and they came with the tunning specs for the 600, I trying to figuire out a jetting a clutching package without having to do to much experimenting.
i just did my 600 and my instuctions dont include 500 either, look at what they changed on 600 and start there, bump 1size on main, needle up.5(check your alt.) then you have two see how sled reacts and clutch from there, you want to bring up engagement with stiffer spring and check wot shift out rpms (to high) add rivit weight to primary. hope that helps
