jetting, elevation chart for 02 MM700
If your looking for Saskatchewan jetting with stock pipe. Use the jetting from stock specs in the tech section and you will be fine to temps of -30C.
With stock pipe I eneded up raising my needles a 1/2 and I ran 145 straight across just for the ease of having everything the same. The coldest I ever tested at was -25C and had lots of safety.
