Hi, I own the last TSS sled a -96 Vmax 600 XT. Standard lug height is as far as I can tell 19mm. Does anyone know what track I can safely put in without having to modify anything. i.e. the radiators. will a 25mm allow for enough clearence?
JohnnyQuest
1.25" track would be perfect for your sled!
You're sure that it won't slap into the roof of the tunnel?
are you putting studs in ?
yammy said:are you putting studs in ?
As english isn't my native language I am not sure what studs are. I am looking for a standard track for allround snowmobiling that fits without any modifications to the sled whatsoever. I mostly ride on the trail but even so 19mm is a bit to little.
JohnnyQuest
Studs are metal ice picks that some people put in their track for icy conditions. A 1.25" (31.75mm) track would be great for the type of riding that you have mentioned! And it will fit without any problems. Camoplast has a variety of styles to choose from
Okay, thank you for the info. Would it be neccesary to change gearing and/or fiddle with the clutch as I imagine the new track would be heavier to pull due to the better grip?
I ran a 1" Hacksaw on my 96XT and that thing loved the new track. You could go with an 1 1/4 but I wouldnt stud (pick) it.
SX_SLAYER
Diversion, you wouldnt NEED to do anything with gearing or clutching, its not needed
