yammyhamer408
hey guys i have a 01 srx i just replaced the PV cuz they hade pulled thrue it is now flashing a cod to me. the sled will not take any throttle it bogs or will rev upa nd start missing and no the THORS is not kicking in. i flashes 7 times fast or 6 times one fo the two. any one had this problem befor i need help asap i have a ride pland for thursday. thanks
did u put them on the good side????and make sure they are ajust properly
kirk700 srx
7 times in 5 seconds is the faulty servo motor but i tried changing my servo motor and still the same finally i found out it was the stater was burned up i dont know if this is the same for you but its something to try
yammyhamer408
im thinking it might be the stater at work the other day we had a srx in with the same probs as mine adn its looking like i need a stator. im hoping not
and i ajusted the PV and what do u mean the good side
yammyhamer408
now the sled will not start or run
BLUE DEVIL 700
Stator!!!
^^^x2 thats where i would be checking,also check for wire rub throughs.
yammyhamer408
found the problem guys the gas line going from the tank to that pump have falen off the tank end the guy i bought it off of must have put one on cuz it was not a yamaha hose and there was no ziptie or clamp on it so i fixed that the code is still coming on and there are no rub thrugh in the wiering harnes at all. stater seems to be fine tones of spark and its strong to.
