converting to long travel
SX_SLAYER
Alexandria, Minnesota
ok guys, i have a 1997 SX 700 and i want to upgrade the front to long travel, i already have an SXR long travel in back and i have the shocks for the front, do i need any other parts? is it a direct bolt on? what do i need to do to get it to work?
thx, Carter
You will need to remove the top shock mount from the short travel shocks. You will also need some bushings for the top mount for the long travel shock either from an xtc,viper, or sxr, anything with long travel front shocks will work. Then they should bolt in.
