theflamanguy
I cant find the 8CR's but I do have a set of 8DN's doing nuttin!
Also looking for a setup for 6-7,000 feet with the 8DN10's if you've tried it?
yep. Ran them at 8000+. Can't remember off hand how they were loaded. They are at home and I am not.
They worked good though.
theflamanguy
Thanks Ryan, I notice they are only under 2 grams different per ramp and the 8cr's needed I think the 13mm and the 17mm rivets for elevation or something close to that. So the 8dn's should only need half the weight added for rivets
Anybody else??
I'm also looking for the elevation/temp chart for the MM700 if anyone has it
TFG
Anybody else??
TFG
I can look at my notes tonight and see what's in them.
As for jetting at 8000+ I ran 130 mains, needles (I'd have to look), and 55 pilots. This was at about 20F for temps. Basically stock sled. NO pipes at that time.
theflamanguy said:Thanks Ryan, I notice they are only under 2 grams different per ramp and the 8cr's needed I think the 13mm and the 17mm rivets for elevation or something close to that. So the 8dn's should only need half the weight added for rivets
Anybody else??
TFG
For stock MM700? If so look in the tech pages.
http://www.zenitram-inc.com/Manuals/MM700TU2.jpg
theflamanguy
Thanks MM, now that I know what elevation stock Jetting is for, I need to know how much weight if any to add to the 8DN10's for 6-7000'? Anyone?
TFG
TFG
