SrXxTrEeM
Power valves....
I am having a hard time tring to clean my power valves on my viper. Yes I let them go way to long.. 4,000 miles. So to get them out I have use a little carb cleaner to break them lose and get them out. Now my question is I don't know if any of the carb cleaner got into the cylinders when I was spraying it(getting by the valves some how) Should I worry about this? I was going to put some oil into each cyclinder. This a good idea? Plus when I was tring to remove mine I heard the servo motor move a little is this going to be a problem? I can get the cables all hooked up ok but will the valves be in the wrong position? Thanks for any info...
