transfer rods/ coupling adjustment?
TJ500
Lockport, Manitoba. Canada
2002 MM700..
For trail riding, I'm just wondering if I need any additional spacers on top side of transfer rods?... There is a small spacer on top and a larger on the bottom... Is this too much transfer and if so what's recomended for agressive trail riding...
If these are identical transfer rods to the 01 SXr, should the spacers (nylon) be the same?...
thanks..
with your wieght on the machine, you should have about the same amount of gap on the top and bottom and more on the bottom if you are a aggressive rider....thats what I found to be the best for the trail. I can find the stock spacer spec if you need it from my Tech Books.
Thanks MrSled... These spacers are stock,(I think), just thought the spacers were placed as they are to provide more transfer when constantly in deep snow?... We do a little trail breaking, but mostly groomed and ungroomed trails...
Thanks..
