sledderbob
Anyone have an M-10 out of your sled. What is the lenght of the mounting cross shafts. I want to remachine the shafts I have to fit in a 2002 v-max. Need an accurate measurement. thanks
sledderbob
Steve
Thanks for the information but could you recheck the front shaft lenght. 12 5/8" is the width of the steel section of the front arm. I think you should have an aluminum spacer on each side that the shaft goes thru. I'm guessing the front should be 14 5/16" based on the rear shaft being 5/8" narrower I am thinking the front should also be reduced by that much. Hope you still have suspension out and can recheck. Lenght of Aluminum spacers would be great information also if possible front and rear. Thanks bob
NY AttakGT
Heads up SledderBob
Bob, I'm sorry. Now I just feel like a boob!
Rear shaft measurement 15 3/4 x1" and the front shaft measurement is 14 1/4 x 1". There are 7/8" spacers on the ends of the Rear shaft along with a 5 1/2" bogey/idler wheel. The front shaft has a slightly smaller spacer (13/16") on each end and the torque arm braquet that mounts to the tunnel. My bad.
-Steve (O.C.) -By the way, I deleted my previous posts as to eliminate any confusion. Let me know if I can be any further confusion..........errrrrr, I mean help.
NY AttakGT
See above editted post
sledderbob
Thanks Steve info is just what I need TY'ers are the greatest. No problem with the small error. measure twice cut once works for me. really appreciate your help.
NY AttakGT
No problem Bob
. Like I said, the M-10 will be out for another week or so if you needed any other info or measurements. -Steve(O.C.)
