Can some of you with PI end dumps post pics of them installed Please?
MountainRx1
Wisconsin
I've got a set of Power Inc end dumps on my buddies Mountain Max, and I have them in there decent, but not overly satisfied with how they fit. I was just wondering if someone could post some pics of these pipes installed? Also, does anyone know what that tab about a foot up the center pipe is sopposed to be conneced to? Thanks. :2strokes:
Not sure what that tab is supposed to hook to so i didn't use it. I just hooked a spring around to pull the pipes down in that area:
Thanks alot, really appreciate it, can you tell me where you have that long spring in the back hooked to, other than the mag pipe? Are you just using the all of the stock exhaust springs? Thanks alot.
That long spring goes from the mag silencer to the frame i believe in the same location where the spring from the stock can goes(same long spring). There are a bunch of holes there so i just picked the one that worked best. It fit nice and tight and kept the pipes off the chain case. I used all of the stock springs plus about 3 or so extra header (swivel) springs.
JohnnyQuest said:
Haven't seen a pic of end dumps in quite a few years.... Quite the configuration aren't they?!
Ya, but boy do they scream.
Those Haucks can't be quiet either are they? I had CPRs (same as hauck) when I had it, I think they sounded cooler, more of a high pitch sound. :2strokes:
You had better silicone the 6 springs from the flanges to the pipes,or they will break. The long spring is to hook in that tab and go all the way around all 3 pipes and hook back into the same tab. Maxdlx
What's silicone going to do? I've ran them like that for a few seasons already.
It takes the vibration out I kept breaking springs until I did it. just put silicone the length of the springwhen installed. Maxdlx
Hmmm, never broken a spring, but I may have to try that.
