yamaha_nisse
Hi,
Want to set back my ignition on my MM 700.. (Goin' turbo).
How is this made, though yammi don't have the adjustable stator.
All tips are welcome
Anyone in here running a MSD ignition? That may be interesting aswell..
OR..
Know if I cud use like a Sno-pro (they got variable ignition timing module) and use it on my MM..?
OR..
You can get timing advance keys...just put them in backwards. I think you can get keys that move the timing up to 4 degrees if thats enough. I believe stock timing on a "RED HEAD" is 20 degrees @ 1600 RPM.
i have an unused timing advance key from hauck, 3 degree. if your interested
yamaha_nisse
800vmax4 said:You can get timing advance keys...just put them in backwards. I think you can get keys that move the timing up to 4 degrees if thats enough. I believe stock timing on a "RED HEAD" is 20 degrees @ 1600 RPM.
That sounds right. I'll try to get ahold of some keys, looking for 3-4 degrees.
bam bam,,, got the Turbo fluu!
