hereismylife
97 vmax xct 600 twin e/r
Just to let you know I have no battery in this because it needs replaced.
Well I searched this a little and trying to figure out to things.
1st my water temp light stays on. I checked with 2 sensors. I checked it in cold water plugged in. I checked it it unplugged. I checked it once it cooled down a little ( this is just still on warm up stage) It will not go off no matter what I do. Anyone know how to make it turn off?
2nd On start up should anything blink? I never had anything come on or blink when I started it up....
thanks
thanks
SX_SLAYER
it problably won't go off cuz ur sled is to hot!!!! lol.....
battery may have to be in sled to make lights work properly,, seen weird things happen without, on electic start machines..
hereismylife
Well yesterday it was not on when I ran the sled. All was good and the light was not on. So I don't think a batt has anything to do with it.
Is there a way to turn it off ( like a test mode?)
hereismylife
still not off..
I looked things over and over. I think something is not right. Dead cold and it is on and will not shut off.
Anyone know how to test the wiring?
Anyone have a schematic for the wiring
This just sucks
This just sucks
horkn
Whammy said:battery may have to be in sled to make lights work properly,, seen weird things happen without, on electic start machines..
I fully agree..
Try putting a battery in it. ES machines of any brand have been known to do ODD things like this with no battery in them.
hereismylife
Well I worked on this again today and no luck I am going to try with the battery and see what happens.
hereismylife
update...
Well it seems like it was the wire right behind the engine. All is good now. right where it curves below the engine. Anyhow it is fixed.
Thanks for all the help again guys...
cool what did you find????? shorting?j_k_auto said:Well it seems like it was the wire right behind the engine. All is good now. right where it curves below the engine. Anyhow it is fixed.
Thanks for all the help again guys...![]()
hereismylife
update....
Yes it was a rub through/bad wire combo... I am just glad you helped me out and I found out what the problem was. Now I can move on to the next sled in line.
Thanks for all your help
daman said:cool what did you find????? shorting?
thats good to hear joe,thats what i thought your welcome buddy.j_k_auto said:Yes it was a rub through/bad wire combo... I am just glad you helped me out and I found out what the problem was. Now I can move on to the next sled in line.![]()
Thanks for all your help![]()
