Track Question
srxguy333
ny
i have an 02 srx 700 was wondering what type of track i should replace the factory one with? i dont plan on studding it and i want to get one that will be good for an agressive trail ride? i just want some suggestions? and also how deep of lugs i can run without having to change anything else?
Don't know much about tracks, I have a predator (1.25) on one of my sleds and a ripsaw on another (1.25), I kinda like the predator better with loose snow and off trail, and the ripsaw works good for groomed trials. There is some newer models out there, try contacting Richmotorsports, he has really good deals and can help you pick the one that will work better for you.
I'm almost sure you can go up to 1.5 inch without changing drivers if you are not runing studs. I just don't know much about srx's but I think os like any proaction chassy.
Nick
You should get a 1.352" Camoplast Cobra. I love mine and did nothing but install it into the machine. Stock everything. Hooks up well on the trail and digs well in the powder. I didn't notice any considerable top end speed reduction with the larger track.
I installed a ripsaw on mine 5 years ago. It's an excellent track. The new model is lighter as well. The only thing that takes some getting used to with the ripsaw is that you can slide as easily in the corners. Pretty much anything is an upgrade compared to the stock track!
Put 1.25 ripsaws on both of my sleds (sx & srx) very happy with them on and off the trail. Did not have to do any nipping of the track like some.
