Carb Tuning
Vmaxkid
Maine
How do you guys tune your carbs? I've got a 02 Viper and wanted to make sure all 3 carbs are running the same. A friend of mine has the mercury sticks to hook into the carbs to sync them but the tool suggests not to use on 2 stroke engines. Any idea why? Will it work anyway?
The flat slides are not like the carbs on your 4-stroke bikes. They dont have a vacuum pipe for you to sync the carbs. Look in the tech section and youwill see where I set them up using a method to measure the slide height. That is all you can do with these carbs. Doug
