T.S.U.Filmz
I am looking for a 141 in track and i am finding nothing. my adjustment when tight is like no more then a quarter IN from the rear bolt being lose. can i put a 144 in track on there or will it be to big. i have like 4IN of bolt to go for the rear axle
The 144 is only 1.5 inches longer at the rear axle. If you can take up say 2.5 inches or better, you should be good. That said tracks vary and all stretch differently. I have a 144 ripsaw that I cannot get to stretch. I would measure your current track and compare first.
schmidtty
141 track
there is a new 141 cobra track available made for arctic cat its lug height is 1.6. in the process of puttin one in my 2000 mountain max have to change drivers though to 3'' pitch. track is single ply and very light
yamaman700
I tried it in my MM, thought I would make it but it wasn't even close. Luckily it was a 144 x 1.5 " crossover track so I just put 9 tooth drivers on the drive axle. I didn't want to go with a rail extension.
