srx & viper hood & shroud
hereismylife
Pa
Website
www.hereismylife.com
I am wondering if it is possible to put a viper hood on a srx? I was looking at the hood differences on the fiche but just figured I would ask..
It what bought this on is I like the 3 pipes on the srx plus the extra stock power. I like the viper hood, gauges, and headlights
So I was thinking about this and wondering if it is possible?
Also I do know you can use the stock srx pipes but I do not want to cut the belly pan out or have hood problems. It would be nice to have the 3 pipes ;)!
If you are going to say just run aftermarket pipes... No 2 reasons
NY does not allow aftermarket pipes plus I do not want to worry about jetting.
Anyone have any good input on this.....
My goal would be I think a 02 srx with the viper hood ect.....
can not run viper hood on SRX and can't run SRX hood on viper have to change belly pans for both. or make a hood out of fiberglass
I had a feeling that was going to be the answer. I was looking for hope on this one...:o|
Well If I change the belly pan will the srx pipes fit under the viper hood ok? I thought it had that raised hood for a reason.
Well I am going to see how hard the belly pan is going to be to change out.
yupp.sell the srx & buy a viper..serioulsly though if you get it to work then you still wont be able to run the viper cdi & wiring harness in it without having problems down the road.to much timing in that box for your sled.i did this mod in a 2000 srx years ago.it was different but i had major problems later on..& you also will disable your dcs also..
best of both worlds
bluemonster1 said:
didn't modsrx put a viper hood on his SRX.
Yes he did and I am trying to figure out what is better to do. I think both ways will take about the same amount of work. I am looking for the best of both worlds here.
