weights of SRX by year
WISH'IN 4 THIS
Manitoba
Can someone put up the weights of each year for the SRX 700 98-99, 2000-02?................................ please!!!!!!!!!!!!!!!!!!
According to yamaha Dry weights;
1998-no info listed but i would say close to '99 528lbs
1999-528 lbs
2000-522 lbs
2001-522 lbs
2002-522 lbs
now you add another 100 lbs for fuel and maybe 200 lbs for you and your gear and that SRX is at about 822 lbs.Man that is a lot of weight to get up to 110 mph.And if you add for all the ice stuck to the tunnel and the suspension..you are probably in the area of 900 lbs.. :eek: :die: Out of my way!!!!!
