shaveing 79 heads
rambo3010
dresbach, mn
how far can i go for a drag set up.im starting with one of my extra 79 motors. the two i have are blown up i think i see why.thay shaved the head only. they didnt mill that little step back in.my question is what else needs to be done, will the chamber be ok its off centerd,im sure you know that already.i want to put the aaen pipes on this one,didnt you guys say there are 2 sets trail and race,im not sure with way to go .im sure ill have a lot more questions.i realy appreceate you guys.hay any of you guys here of charlie machnally he lives up the road from me.
AAENS TRAIL PIPES WERE NO BETTER THAN STOCK. RACE PIPES WORKED AWSOME, BUT MUST WORK WITH FULL PORTING, .44 CARBS etc. AND NO LESS THAN 110 RACE FUEL. THOSE HEADS STOCK WERE 21 cc. SO THERE IS ALOT OF ROOM THERE FOR MILLING, BUT ITS A MUST TO CHECK SQUISH AND RUN RACE FUEL WHEN YA START CUTTING. 3:16 (yammie tony)
you must also remeber that the squish will be different if you run wiseco pistons and the heads cannot be cut as far
