No lights
nbsledder
This a 700 xtc '98 At first the lights would go dim and then go out but only on high beam,you could run it on low beam they were fine but the high beam would only run for a short time,now i have no lights at all and the tach only works when you push the dimmer switch to low beam...does anyone know what this could be?
I would like to add that the tach and h+t warmers are working...do they run off of the lighting coil?
