srx70024
The center to center on my 01 SRX is a little off, engine need to come back a bit. I used my center to center tool from Maxx Perf.
Can anyone recommend how to do this ? There doesn't appear to be adjustment with the stock engine strut.
Matt
Matt
you can adjust it...you need to crack the engine mount bolts loose and adjust...it will go...you want it slightly twisted so under load it will be straight...
srx70024
So, the engine should be a little farther forward than what the tool indicates as ideal center to center ?
the center to center should be correct but the offset with the flat bar will be off more on the front side ....I use the billet tool that does both center to center and offset and it works great!!
