no start
check all connections from battery to sled, clean with wire brush and make sure there tight after cleaning two posibilitys right off pos is dirty/oxidized on starter solenoid,ground to sled oxidized or bad solenoid, check voltage at battery then solenoid then when key is turned, at starter side of solenoid and at starter should all be close if they are then starter is bad
get a stator cover gasket, and ask to see the tech bulletin in the 04 that will show the problem. while your at it, drop your oil as well
