srx 700 port times
PowerValve
sweden
I would like to know port times for a srx 700 year 2000 ?
it is that we have thought the portal. and it will give 12 extra hp
port times as in durations? turk has posted in the tech pages, the dimensions from the cylinder deck, to the port roofs and floors. from there, you can take those dimensions, stroke, and bore dimensions and use the formula found in the graham bell book and get your duration values. or, you can put a degree wheel on the crankshaft, and find out durations and blow down time that way. hope this helps. if you need me to figure out the durations for you, i can.
