Limiter straps= twisting
chadg
redford, mi
Hey guys I long tracked my 97 xtc 600 136' and I ended up having to pull the limiter straps all the way up because I was burning through hyfax within 25 miles. Sometimes the hyfax would get so hot that it would melt and stick to the track clips..
I know for a fact that the suspension is twisting up on itself because the limiter straps are all the way up.
Is there a solution to this????????
I thought about a relocation template but I do not think that would help at all, and or drop brackets.
Maybe just have to get an M10?
MY GOAL IS TO BE ABLE TO LET OUT THE LIMITER STRAPS ALL THE WAY, TO RELAX THE SUSPENSION.
thanks guys Chadg
Are all of your holes lined up correctly? Maybe you have the back in the tunnel too far?
I am sure someone here will have a far better idea for ya. But I would remeasure all of your points of contact. What skid did you put in?
I know with my M-10 Master, I still need to get drop brackets for the rear due to my front shock having to much pressure. So much it lifts my skis off the ground just sitting there. I have my limiter on the 2nd hole I think, but I want to use the full shock length, so out it comes and dropped it goes...weeeeeee.
I hope you solve this, sounds expensive in hyfaxs.
