Allen Shores
Can this be fixed? looks like it's welded together where the pins are for the rod bearing. I know some cranks can be pressed apart, but it looks like this might not be the case here. Notheing on E-Bay right now. Any advice will help. Thanks
kirk700 srx
There is a few on e bay now i was lookin at one this morningAllen Shores said:Can this be fixed? looks like it's welded together where the pins are for the rod bearing. I know some cranks can be pressed apart, but it looks like this might not be the case here. Notheing on E-Bay right now. Any advice will help. Thanks
rod
My rod got bent too, (srx 600)i ordered a new rod+ bearing for 60 usd
work 200usd.
/lars
work 200usd.
/lars
2strokinit
Crank
The welds can be ground away and the crank is then pressed apart like most 2 strokes. Fixing it aint cheap as the crank assembly is pretty pricy$$ Also make sure and investigate why it bent the rod.
there is place that you send your crank and they send you one that is fix it is call the crank shop cost is 350.00 plus shipping viper cranks are more bought one last year from him they where list as the one of the crank repair plase ok by yamaha when they had crank problems with the SRX i have talk to him he know his stuff if need i can get you guys his #
Contact # is always good thing to post up.DARV said:there is place that you send your crank and they send you one that is fix it is call the crank shop cost is 350.00 plus shipping viper cranks are more bought one last year from him they where list as the one of the crank repair plase ok by yamaha when they had crank problems with the SRX i have talk to him he know his stuff if need i can get you guys his #
