VMAX535
What is a good primary and secondary set up for this sled. Sled is totally stock. Is there a good set-up to help it upshift faster and hold rpm.
I'm helping out a member on vmax4.com. Any input welcome.
Thanks,
Thanks,
VMAX535
ttt.................
stocks not bad.. 80mph, buddy had a 96,, ran about 90 on speedo.. stock also.. gutsy engine thirsty for gas and oil.. (i think that 96 turns more rpm then the 94??..) otherwise if rpms are on to your specs.. springs are cheapest to try. They can get weak.. after time.., Check componets in primary & secondary..
8ab weights; 50/44 helix, green secondary spring at 60, Clutch it to run at 7800 rpm.,2.4 gram rivets in both holes is close to start with.VMAX535 said:What is a good primary and secondary set up for this sled. Sled is totally stock. Is there a good set-up to help it upshift faster and hold rpm.
Thanks,
