1991 - 1993 Exciter || Owners Please Help
motofishsled
deerpark new york
I am installing a EXCITER || rear skid in a 89 phazer . I need 2 measurements from an EXCITER || . I need the center to center of the front and rear arms ( It may be easier to measure between arms because rear arm is mounted on triangle plate ) . And the center to center of drive shaft to front arm . THANK YOU
I don't have and exciter but did that not have 121 inch track and don't the 89 phazer have 116inch track ?
1991 -1993 EXCITER || rear suspension
TONY , THANK YOU VERY MUCH . The measurement i need is the center to center distance between the front and rear (A or W arms ) . The rear arm is mounted on triangle plates making it hard to measure center to center . A good way to measure would be to hold tape measure between front and rear arms in tunnel . THANKS AGAIN , SAL 1989phazer deluxe Bender wide kit Fox front struts RPC stealth pipe SX pistons ported cases drilled carbs RPC engine tensioner Comet 108exp exciter || secondary Exciter || proaction 121" track SOON
27" from inside to inside of shafts , this is the measurements from my 93 exciter sx
Thank you RAMBLNMAN . Thank you TONY . This was my first brand new sled , bought in 1988 , so it has sentimental value .I restored it in 2007 .
