Swapping primary clutch caps?
Phazer_II
Alaska
I'm working on a clutch from a MM600, but it's totally shot. I have another clutch from a MM700, but the spring is wrong. The 600 has the short spring, and the 700 has the tall spring. Other than possible balance issues, can I put the 600 spring and short 8BV cap in place of the 700 spring and tall 8DF cap?
As long as you have the short spring and short cover together you'll be fine. They swap between clutches as long as you use the right spring for the cover you have.
Why not be safe and find a long spring the same rate as the short one. The cover and spider are balanced for a reason. Maxdlx
