01 SRX jetting
fourbarrel
VIP Lifetime Member
Which cylinder is jetted richer on the 01 SRX the pto or mag?I've got a buds carbs apart and was noticing the mains with the richer one being in the pto carb rather than the mag;isn't this backwards?I know this sounds stupid even after I've had my own apart dozens of times but for the life of me I can't remember if mine is jetted richer on the mag side or pto.
Thanks Daman I thought #1 was the pto but wanted to make sure before I switched any jetting.I saw the stock specs in the tech section but kept second guessing myself in that I was always under the impression that the mag side was richer in the triples.I've had some VM round slides apart off Doo twins and they are jetted richer on the mag side.Man it's stupid things like this that really make me think I should take notes :o| LOL.
Theres nothing wrong with beeing 100% sure of somthing,i'm the same way,somtimes i can't sleep at night when something bugging me...lol.
Well here's a new twist to the mix LOL this sled has a Bender cold air kit on it,which I knew but neglected to mention,and this afternoon I was rummaging through a box of clutch parts my bud kept trying to find his original helix to take the bushing out of I found the install sheet for the cold air kit.Come to find out Bender has the jetting for their kit with the 152.5 richer main on the mag carb and 150's on the pto and center.Learn something new every day ;)! .
Man I really need to write stuff down either that or let up on the Bacardi.Naw it's easier to get a note pad. :rofl:
the '98-'99 700 srx's had the mag cylinder jetted fatter than the center and pto. on the '00-'02 srx's the pto is jetted fatter. are you sure that bender has the mag jetted fatter than the pto, on your buddies '01?
