Vector88
i want to put a 16inch wide track on my 04 viper mountain. she is a 144 with stock proaction plus suspension. i know that i need new drop brackets but i was thinking of making a set out of sheet metal and making the spacers to go on the shaft. what other mods will i have to do to run this track? also if anyone has a set of drop brackets to run this track send me a pm i will get them. thanks
..SNAKEBIT..
I bought my drop brackets from CB Performance 2oooSRX on here
I thought you could use the mountain drop braket but had to trim them?
I know i direction for this on snowest and I think I printed it out a few years ago
might still have a copy? I will look
Vector88
yeah it would be great if you can find that. id like to see it. still ridin here in labrador and may need a new track soon. was plannin on running the 16 wide track
jt specialties
Your stock brackets are ok. Just move the suspension to the lower hole. As for the 16 wide. You will need to grind a couple of bolt ends and nuts down a little bit at the chain case, also roll it thru and grind any rivots that hit. Other than that you will notice a big differance. Have fun
