Air jet
The Snakester
Northern Ut
hey guys where are the air jets on my carbs? My pipe specs call for a different jet and I don't know where they are. Maybe I'm dumb you tell me
snakester, Are you sure the directions are asking you to change the air
jets. Most kits change pilots, mains and needle clips and turns on the fuel screws. What pipes are you running? For the air jet look in the intake of your carb the air jet is located at the bottom and is slotted for a screwdriver. These jet clog easilly with belt dust and make sleds run terrible.
You'll find em where Mac says, I put the .7 air jet in my MM, needed to back out fuel screw 1/2 turn also, had a bad lean bog after puttin on Benders onto my MM. Them Benders like the fuel.
