Skid Questions on install.......
WEATHERBY460
IL
How do i get the last bolts in the skid, in the rear. I am about 2" away. The skid need to go about 2" foward to line up with the mounting plates in the frame. All the other bolts are in and the track tension is loose. Also, should the bolt/nut combo located on the bottem below this, if loose, the rear shock pivots....should that be tight or loose?
V-max 4 92 skid
here is a picture.
also...the screw/nut above the orange handle...should that be tight or loose?
Thanks for any help....so close
That skid has no transfer rods. You can release the rear strap seen in the pic, line up yhe bolt hole and then compress the skid to reattach the strap. Maxdlx
