Does anyone know how wide the top ski shock mount is? Or how wide the top eye is on the shock itself?
I picked a 97 SX beacause I know the mount on the bulkhead is for an eye shock. Other models may work.
SO the mount on the 97 sx are a fork mount. Unlike the 02 Mountian Max's are a fork style shock with an eye shock mount.
ANybody got an SX that can pop the hood and measure the shock mount?
musselman
The with of the top mount should be the same as the bottom mount of any pro-action front shock. I just measured it and the bushing in the shock is 30 mm wide. Hope this helps.
gild
brkt
97 SX has eye mounts with a bracket off the bulkhead. The fork mount shock is the long travel SX with no bracket 2000 and up and same as Vipers
musselman said:The with of the top mount should be the same as the bottom mount of any pro-action front shock. I just measured it and the bushing in the shock is 30 mm wide. Hope this helps.
Thanks.
gild said:97 SX has eye mounts with a bracket off the bulkhead.
My sled now has fork shocks. I am putting on eye shocks. I will have to order the bracket off of a 97 SX.
