2000 srx 700 help
madzx2
Osceola Wi
i recently recieved a 2000 srx 700. i was wondering if anyone has suggestions on how to clutch it. it has vforce reeds, mega power heads, and has been ported by mark giametti.
GIAMETTI STUFF REALLY HONKED WELL. I HAVE A SET OF HIS CLYS ON MY 2000 SRX WITH SOME REVISED PORTING. LIKE MOPAR SAID, WHAT ARE YOU DOING WITH THIS. 3:16 (yammie tony)
yes they are stock pipes. it will be used mostly for riding off trail and some drags once in a while. im totally new to yamaha and so far this site is the best info i have found. thanks
Clutch It To 8400 Hundred Down Low Up To 8600 In The Mid And Since It's Ported On Ice It Will Probaly Creep Its Way To 8700/8800 On The Big End , And Thats Ok For Big #
Try This It Should Be Close ,you Can Fine Tune For Your Weight Etc....
Www
8dn 10 Or 20 / 51 To 52 .5 G .
Red Dot Sec. Spring 60-70 Wrap
51/43 Helix
madzx2, you don't happen to know what rpm (rpm of peak hp), that this thing is now ported for? 8400-8500?
when you say off trail riding, you mean like boondocking in the powder?
yea i do alot of boondocking of trail. i dont know what what the rpm is now. i got the sled from a member on this forum. his screen name was daliyama ithink thats how its spelt.
it has a red primary spring, a black with green dot secondary spring, heavy hitter weights (not sure what they wiegh) and a mega power helix(only markings i t has on it is m-3) this is whats in it now? what angle helix is it?
