Starting sequence question
SinNH
NH
Because I just bought the Viper in Jan and just finished the summer maintenance,rebuild carbs,clutch rollers, fuel filter,etc,I need someone to verify that when turning the key on to "on", you are supposed to get no lights or instruments and they activate when the engine starts.
On "start" the engine will crank fine.
I don't want to start it, it's fogged.
The only electrical stuff I did was remover the battery and disconnect the needed connectors to the hood and carb setup.
The manuals I have don't give a clue.
again
2002 Viper ER
